8 years agoOpenCL on FPGA Not able to generate hardware for matrix_mult.cl
Hello everyone, I am trying to compile a very basic matrx_mult kernel (also same error occurs for hello_world) for a nallatech 385a board. However, always I am getting the following error: ...
8 years ago --- Quote Start --- That sounds very strange. Honestly I wouldn't be quick to judge in this case; your issue could be caused by a recurring transit problem that just didn't happen this time, and could happen again later. The compilation machines I personally use are all remote machines and I just connect to them via SSH, so the problem is certainly not from remote connections. --- Quote End --- Just checked with two more kernels and I can verify that the ethernet causes the random crashes during compilation. As long as the machine is offline, compilation worked fine.
