8 years agoOpenCL on FPGA Not able to generate hardware for matrix_mult.cl
Hello everyone, I am trying to compile a very basic matrx_mult kernel (also same error occurs for hello_world) for a nallatech 385a board. However, always I am getting the following error: ...
8 years ago --- Quote Start --- I disconnect the machine from the network ( I took out the Ethernet cable ) and it worked in the first go. Previously, I used only ssh connection to the machine (only through Tmux e.g byobu, screen etc). Is anyone experienced something similar before??? --- Quote End --- That sounds very strange. Honestly I wouldn't be quick to judge in this case; your issue could be caused by a recurring transit problem that just didn't happen this time, and could happen again later. The compilation machines I personally use are all remote machines and I just connect to them via SSH, so the problem is certainly not from remote connections.
