8 years agoOpenCL on FPGA Not able to generate hardware for matrix_mult.cl
Hello everyone, I am trying to compile a very basic matrx_mult kernel (also same error occurs for hello_world) for a nallatech 385a board. However, always I am getting the following error: ...
8 years agoHello,
Thanks again for the reply. I manage to compile and run successfully on the fpga. I compiled the matrix multiplication kernel and took 2 hours and 25 minutes for completion. However, the problem was very odd. It was due to the network connection SOLUTION: I disconnect the machine from the network ( I took out the Ethernet cable ) and it worked in the first go. Previously, I used only ssh connection to the machine (only through Tmux e.g byobu, screen etc). Is anyone experienced something similar before??? Also, I discover that some of the pre-complied examples given by nallatech for my current board or not compilied for the current BSP that they claim. As many of them failed to run with a CL_INVALID_BINARY, while the rest working out of the box.
