8 years agoOpenCL on FPGA Not able to generate hardware for matrix_mult.cl
Hello everyone, I am trying to compile a very basic matrx_mult kernel (also same error occurs for hello_world) for a nallatech 385a board. However, always I am getting the following error: ...
8 years ago --- Quote Start --- You are getting another random crash: Since the crashing point seems to be changing, my guess is that some component in your system must be unstable. This could be the CPU, the memory, the disk, or even the network if you are using a network storage system. Do you have any other machines to use for a compilation test? --- Quote End --- I can try a different machine. However, the issue is that for the Altera SDK I got floating licence, while for the nallatech BSP the license is binded with the MAC address of that machine. Also, is the only machine around with 64GBs of RAM. I am currently using CentOS 7.4 which is a supported OS for compilation and runtime according to nallatech. Do you think an other OS might be more stable for the current work-flow? Any suggestions? Thanks again for the replies!
