8 years agoOpenCL on FPGA Not able to generate hardware for matrix_mult.cl
Hello everyone, I am trying to compile a very basic matrx_mult kernel (also same error occurs for hello_world) for a nallatech 385a board. However, always I am getting the following error: ...
8 years agoI managed to get a compilation pretty far. It took about an hour and 15 minutes to fail this time for the matrix_mult.cl kernel.
The last error message was:
Info: Command: quartus_cdb -t import_compile.tcl
Info: Using INI file /home/admin/fpga_experiments/nallatech/examples_p385a_sch_ax115/matrix_mult/matrix_mult/bin/matrix_mult/quartus.ini
Info: Checking for OpenCL SDK installation, environment should have INTELFPGAOCLSDKROOT defined
Info: INTELFPGAOCLSDKROOT=/home/admin/intelFPGA_pro/17.1/hld
Info: Successfully completed BAK flow
Info: To reduce compile time on future compiles, you can generate a BAK cache by adding the arguments '--bsp-flow regenerate_cache' to aoc to skip BAK
Info: Retry strategy set to "retry-flat"
Info: Initial preservation set to "final"
Info (125061): Changed top-level design entity name to "top"
Info (125061): Changed top-level design entity name to "kernel_system"
Info (16677): Loading synthesized database
Info (16734): Loading "synthesized" snapshot for partition "root_partition".
Info (16678): Successfully loaded synthesized database: elapsed time is 00:00:03
Info: Performing a fit attempt
Error: Quartus Fitter has failed! Breaking execution...
I am attaching also the generated log. Any suggestions regarding that? I never seen this error message before or I either my compilation went that far. P.S the matrix_mult is directly taken from nallatech example rar for my board. I didnt modify it.
