9 years agoopenCL memory error
Hello, This is my first thread, I´m new at openCL and I´m doing some work to integrate this technology with some other software. So I´m trying to execute an aocx inside another program written...
9 years agoHello Fand,
Yes, the other program runs in the same SoC system with the same aocx. It´s just that my program is more large and calls more libraries. There´s also another difference, this init() function is called in the main() of the application that works. In the second case, init() is called from an object that belongs to a library. Another important thing is that is of key importance that the aocx is loaded by code, as it gives enormous flexibility. I´m using a de1SoC [http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&no=836] Thanks for your help, I will try something else. I have included the init function without being part of the class that is in the library. I will try to include the init function as a method of my class. I will tell you my results this evening. Thanks for your help! Ricardo
