9 years agoopenCL memory error
Hello, This is my first thread, I´m new at openCL and I´m doing some work to integrate this technology with some other software. So I´m trying to execute an aocx inside another program written...
9 years agoThanks a lot for your answer, I will try as you say. First I will compile without the redirection, it can give problems for me because I don´t execute from the same path as the executable is. Second I will backtrace with gdb. That´s something I have done and the program gives me the error in clCreateProgramWithBinary, but it also says: CL_INVALID_PROGRAM, this result is different from the one I have when it is normally executed. I will copy the message as soon as I try your idea, thanks a lot!
Regards, Ricardo
