11 years ago
OpenCL Linux license issues
I have installed Quartus 13.1 Under Linux with an updated license including the OpenCL SDK license. The license is correctly installed as can be seen through the Quartus license Windows. However, the command line "aoc --board de5net_a7 blank.cl" indicates that the OpenCL license is missing when using the de5net Terasic blank project. Does anybody has an idea about this issue? Thanks.
    Are you sure? Just because you see the license in Quartus does *not* mean the variable has been set on the command line, which is required.
    Also, have you bound the license to an ethernet interface other than eth0? Only eth0 will work on Linux for node-locked licenses.
