9 years agoopencl in DE5NET board
Hi, I set up the OpenCL environment according to the DE5-NET OpenCL manual for Altera SDK OpenCL 16.0. My computer environment is shown as follows. OS: CentOS 6.5 X86_64 Altera ...
9 years agoWhy are you programming the FPGA offline? The host code will automatically program the FPGA at runtime.
You should probably remove the quotation marks from your LD_LIBRARY_PATH. Also your screenshots are too small and cannot be read. Finally, you are using an old version of Quartus/AOC; always try to use the latest version compatible with your BSP, which in your case would be 16.1.2.
