9 years agoOpenCL guidelines to use physical pins of fpga
Cheers, I am beginner with OpenCL SDK for cyclone V, I have experience building projects in Cyclone IV using NIOS soft core and fpga IP modules. Now I am trying to use OpenCL in Cyclone V ...
9 years agoI'm not sure what you're trying to do in your first question, but as far as your second question is concerned, the answer is no. The BSP (the board_spec.xml file you mention) is responsible for configuring the I/O and creating "space" on the FPGA for the kernel hardware, which is created by compiling your kernel code with aoc. You can create OpenCL libraries that include RTL code, but there is no way to add or change the I/O of the device through OpenCL.
