11 years agoOpenCL for Arria 10 in Quartus 15.1
Hi, I found there is an updated Quartus 15.1 available on Altera download site. Does it support OpenCL-FPGA mapping for new products like Arria 10? I'm asking since Arria 10 was mentioned in "A...
10 years ago --- Quote Start --- So what will happen if you copy arria_no_interface example BSP from AOCL15 to AOCL15.1? Will that still work? Does that mean it will not give correct area/speed estimate? --- Quote End --- Don't. THe 15.0 BSP doesn't used QHD or PR...it is a flat design that only supports JTAG programming on ES2 silicon with PCIe Gen2x8 and slower speed DDR. YOu want to start with the new BSP for 15.1 which has PCIe gen3x8, full speed DDR4 and QHD with PR support for programming.
