9 years agoOpenCL design without a host
I'm quite new to OpenCL. Is it possible to create an OpenCL kernel design without the need for a host ? watching the latest OpenCL tutorials for AOCL SDK 16.1 suggest kernels can now be started...
9 years agoIt is certainly possible with autorun kernels, check "Intel FPGA SDK for OpenCL Programming Guide, Section 2.3.1.2, Omit Communication Hardware between the Host and the Kernel". Note that if you are using autorun kernels, you are pretty much on your own for functional and performance debugging.
