QTian
7 years agoOpenCL clGetDeviceIDs() returns a wrong num_devices
* Environment FPGA board: Arria 10 GX FPGA development kit(DKDEV10AX115SA) OpenCL and Quartus version: 18.1 pro. OS: Win10(64bit) PC: Dell precision tower 7910 (with two CPU installed) * Problem...
MuhammadAr_U_Intel
Contributor
7 years agoHi,
To workaround this problem, set the environment variable called "CL_OVERRIDE_NUM_DEVICES_INTELFPGA". set it to be 1 so that the number of device will be overwritten to be 1.
You can find the detailed workaround in release notes.
Arslan
