QTian
7 years agoOpenCL clGetDeviceIDs() returns a wrong num_devices
* Environment FPGA board: Arria 10 GX FPGA development kit(DKDEV10AX115SA) OpenCL and Quartus version: 18.1 pro. OS: Win10(64bit) PC: Dell precision tower 7910 (with two CPU installed) * Problem...
MuhammadAr_U_Intel
Contributor
7 years agoHi,
Thanks for the information.
Here is a possible solution to root cause the problem.
The idea is you can unintall all the bsps, and only install the a10_ref.
1.Can you confirm which BSP are you using ? Is Arria10 GX BSP that comes with installation package "a10_ref" and is used during aocl install ?
2.Could you share the console output when doing aocl install and aocl uninstall ?
3.To cross check if there is any other BSP installed, make sure there is only one fcd file in the directory specified by the reg key (ie. HKEY_LOCAL_MACHINE\Software\Intel\OpenCL\Boards)
4.How do you compile the host? By using Makefile or using Visual Studio?
Arslan
