OpenCL clGetDeviceIDs() returns a wrong num_devices
Dear Arslan,
After forcing the NVIDIA and Intel(R) FPGA Emulation Platform disabled, by changing register value, the output is like:
Initializing OpenCL
num_platforms: 1
print out platform info from No. 1 upto No. 1
Platform number 1:
Platform Name: Intel(R) FPGA SDK for OpenCL(TM)
Platform Profile: EMBEDDED_PROFILE
Platform Version: OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 18.1
Platform Vendor: Intel(R) Corporation
This platform has 128 device(s), and its 1st device is:
Querying device for info:
CL_DEVICE_NAME = a10gx : Arria 10 Reference Platform (acla10_ref0)
CL_DEVICE_VENDOR = Intel(R) Corporation
CL_DEVICE_VENDOR_ID = 4466
CL_DEVICE_VERSION = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 18.1
CL_DRIVER_VERSION = 18.1
CL_DEVICE_ADDRESS_BITS = 64
CL_DEVICE_AVAILABLE = true
CL_DEVICE_ENDIAN_LITTLE = true
CL_DEVICE_GLOBAL_MEM_CACHE_SIZE = 32768
CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE = 0
CL_DEVICE_GLOBAL_MEM_SIZE = 2147483648
CL_DEVICE_IMAGE_SUPPORT = false
CL_DEVICE_LOCAL_MEM_SIZE = 16384
CL_DEVICE_MAX_CLOCK_FREQUENCY = 1000
CL_DEVICE_MAX_COMPUTE_UNITS = 1
CL_DEVICE_MAX_CONSTANT_ARGS = 8
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE = 536870912
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS = 3
CL_DEVICE_MEM_BASE_ADDR_ALIGN = 8192
CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE = 1024
CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR = 4
CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT = 2
CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE = 0
Command queue out of order? = false
Command queue profiling enabled? = true
Platform: Intel(R) FPGA SDK for OpenCL(TM)
Using 128 device(s)
Using AOCX: vector_add.aocx
Launching for device 0 (1000000 elements)
Time: 183.060 ms
Kernel time (device 0): 174.776 ms
Verification: PASS
Best,
Qingyuan
