13 years ago
One Register of an array will not reset
I've created a register array (8x9) in VHDL and I'm resetting registers 6-0 in one process and register 7 in another. The problem is register 7 is not being recognized as getting reset and this causes the compiler to optimize all the registers out. ModelSim shows the problem so I'm sure the problem is controlling the contents of register 7 but I can't see the problem in the code. I've reduced the code to the absolute minimum below. Any thoughts would be appreciated.
 library IEEE;use IEEE.STD_LOGIC_1164.ALL;
use IEEE.numeric_std.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
Entity FIFO_TEMP is port(
    DATA_IN:        in        STD_LOGIC_VECTOR(8 downto 0);
    DATA_OUT:    out    STD_LOGIC_VECTOR(8 downto 0);
--    WORD_RDY:    out     STD_LOGIC;
--    FIFO_FULL:    out    STD_LOGIC;
--    WORD_RD:        in        STD_LOGIC;
--    WORD_WR:        in        STD_LOGIC;
    RESET_N:        in        STD_LOGIC;
    SYS_CLK:        in        STD_LOGIC);
end FIFO_TEMP;
Architecture FIFOXN of FIFO_TEMP is
    type Register_Array is array(7 downto 0) of STD_LOGIC_VECTOR(8 downto 0);
    signal    Fifo: Register_Array;
    signal    New_Word:    STD_LOGIC_VECTOR(2 downto 0);
    signal    Wd_Latch:    STD_LOGIC;
Begin
    process(SYS_CLK, Fifo, RESET_N)
    begin
        if RESET_N ='0' then
            for i in 6 downto 0 loop
                Fifo(i) <= (others =>'0');
            end loop;
            New_Word <= "111";
        end if;
    end process;
    process (SYS_CLK, RESET_N, Fifo)
    begin
            Fifo(7) <="000000000";
            Wd_Latch <= '0';
        end if;
    end process;
end FIFOXN;
