9 years agoOne or two bank memories issue
I am testing "hello_wolrd" example for cyclone V by using OpenCL sdk and "c5soc" profile board on the compiler. I followed the getting started guide and it works perfectly.
However, when I try to use another board profile as "c5soc_sharedonly" this does not work, the issue is exposed at the moment of running the host application and this indicate a "different name of device issue", so based on this issue, I edit the "board_spec.xml" name field to change just for c5soc (deleting "_sharedonly" part), and also the folder of the board was edited with c5soc only. By avoiding to have conflict with c5soc original board profile, I move the folder to another place. And again I compile but this time using "c5soc" board profile ( c5soc_sharedonly edited) its compile correctly but this time when I try to run host application linux get freezed.
root@socfpga:~# ./host
-sh: ./host: cannot execute binary file
root@socfpga:~# chmod +x host
root@socfpga:~# source ./init_opencl.sh
Error: could not insert module /home/root/opencl_arm32_rte/board/c5soc/driver/aclsoc_drv.ko: File exists
Querying platform for info:
CL_PLATFORM_NAME = Altera SDK for OpenCL
CL_PLATFORM_VENDOR = Altera Corporation
CL_PLATFORM_VERSION = OpenCL 1.0 Altera SDK for OpenCL, Version 16.0
Querying device for info:
CL_DEVICE_NAME = c5socCyclone V SoC Development Kit
CL_DEVICE_VENDOR = Altera Corporation
CL_DEVICE_VENDOR_ID = 4466
CL_DEVICE_VERSION = OpenCL 1.0 Altera SDK for OpenCL, Version 16.0
CL_DRIVER_VERSION = 16.0
CL_DEVICE_ADDRESS_BITS = 64
CL_DEVICE_AVAILABLE = true
CL_DEVICE_ENDIAN_LITTLE = true
CL_DEVICE_GLOBAL_MEM_CACHE_SIZE = 32768
CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE = 0
CL_DEVICE_GLOBAL_MEM_SIZE = 1073741824
CL_DEVICE_IMAGE_SUPPORT = true
CL_DEVICE_LOCAL_MEM_SIZE = 16384
CL_DEVICE_MAX_CLOCK_FREQUENCY = 1000
CL_DEVICE_MAX_COMPUTE_UNITS = 1
CL_DEVICE_MAX_CONSTANT_ARGS = 8
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE = 268435456
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS = 3
CL_DEVICE_MEM_BASE_ADDR_ALIGN = 8192
CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE = 1024
CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR = 4
CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT = 2
CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE = 0
Command queue out of order? = false
Command queue profiling enabled? = true
Using AOCX: hello_world.aocx
Reprogramming device with handle 1
I am thinking that the RTE running over SOC-FPGA linux os is just compatible with two banks of ram memory project, because the c5soc_sharedonly profile has one bank memory and it is the only difference with c5soc board profile. Someone has more information related to this. I will be deeply thankful for any help.1 Reply
I got the solution.
As I am using other c5soc profile board, it is needed to reprogram with aocl 1) Run comand: "aocl reprogram /dev/acl0 hello_world.aocx" 2) Then you can run the c5soc shared only project: "./host" P.D: Always check the profile board that is running with coamand "aocl diagnose".
