SS5
8 years agoOnchip FIFO Memory Core [Avalon-MM Write Slave to Avalon-MM Read Slave]: Help In NIOS Programming Code
Hello, I want to write 32-bit data into FIFO and read the data from FIFO. So, I have followed this FIFO configuration :Aalon-MM write slave to Avalon-MM read slave. Questions to be clarified: I...
a_x_h_75
Contributor
8 years agoThe base addresses are defined in the 'system.h' file (that you already have in your #include list).
Cheers,
Alex
