JHatt7
7 years agoOn Linux, I need to program my Arria V using an .sof and the serial configuration device with a .jic file. The .sof loads ok. Attempts to load the .jic always fail. Can you tell me what I am doing wrong?
Could someone check out my use of the quartus_pgm command? I have one Arria V FPGA on the JTAG bus. Its .sof image is supposed to have code that would allow me to program a serial configuration devic...
JHatt7
7 years agoDear WolfGang,
I have access to a Windows machine. I downloaded Quartus Prime Software and wanted to execute it since there seems to be a lot of Windows examples in your documentation, but few with Linux. However, I have no license. We are in the role on this project as manufacturer. Our images are provided to us from the customer. So I am stuck with an .sof and a .jic file.
Can you get for me a temporary license so I can run the Quartus program on Windows? Also, you say Quartus Programmer. I see a download for Quartus Prime Software. Is there a difference? Which should I use?
Setting aside all other considerations, which quartus_pgm option should I be using to load the .jic file on Linux? I need to stop guessing.
---jjh
