On Linux, I need to program my Arria V using an .sof and the serial configuration device with a .jic file. The .sof loads ok. Attempts to load the .jic always fail. Can you tell me what I am doing wrong?
Hi JHatt7 ,
Have you try program your .jic file using Quartus Programmer? Is it working?
Based on your attachment .txt, you got an ERROR ID[290040]. This error mean the Programmer cannot communicate with JTAG chain.
There are several reason for this:
- the board is not powered on
- the programming hardware is not connected
- OR there is a problem with the board, such as a short circuit.
Kindly tried program your .jic file with Quartus Programmer.
And let me know the result.
- JHatt77 years ago
Dear WolfGang,
I am confused with what software I can use to 'try program your .jic file using Quartus Programmer ...'
I presume you want me to use the Microsoft Windows operating system. This this correct? I have access to one of these and presuming I am correct, I now have a software selection of products that are available for this platform that are similar to but not the same name as 'Quartus Programmer'.
I see three flavors of Quartus Prime Standard Edition: Pro, Standard, and Lite. Do any of these meet our needs for what you would like me to do?
I am informed from my IT group that the Quartus Prime Standard Edition Lite does not require a license. Would this meet our needs?
---jjh
- ShafiqY_Intel7 years ago
Hi JHatt7,
Quartus Programmer tools come with Quartus software. Quartus Programmer tools allows you to program and configure Intel FPGA.
You also can download the stand-alone software of Quartus Programmer tools from Intel FPGA website ( http://fpgasoftware.intel.com/18.1/?edition=standard&platform=windows&download_manager=dlm3 )
Below is Quartus Programmer tools looks like:
You can try program your .jic file using Quartus Programmer first.
- JHatt77 years ago
WolfGang!
As can be seen in the image below, I was able to program my .jic file into my serial flash! Thank you for helping me with the required Windows software!!!
The programming took about 6 minutes. Is this normal?
I now know that I do not have a problem with my CCA or my .sof image or my .jic image. Now, how do I load the .jic file using Linux? I test and program my CCAs through an automated Perl script on Linux.
I can load my .sof image without a problem using quartus_pgm. So how do I load the .jic file from the Linux command line?
---jjh
To WolfGang or to anyone else who may know, I need to program my serial flash with Linux commands. How is this to be done? Can this question be escalated to someone who knows the answer?
Hi JHatt7,
Since you able to program it with Windows version, I dont think you have an issue with .jic file/broad issue. Thus, I suspect it might be your Linux administrator is the issue here.
Have you tried to download Quartus Programmer (linux version) into your linux system? - (just for your experimental test only)
Did you able to program .jic file with Quartus Programmer (linux version)?
