Yamada1
3 years agoOn-chip FIFO aclr signal
It would be helpful if you could teach me about the FIFO provided by IP.
As the title suggests, it would be helpful if you could teach us the following points regarding the behavior when the aclr s...
- 3 years ago
The 3 different functionality of aclr in Table 11 is depends on the how you are proccessing the aclr signal, means how the aclr behaves in different scenarios. i.e., when the aclr is depend on the write clock or read clock and when it is not dependent on any read/write clock.
For Add circuit to synchronize 'aclr' input with 'wrclk' this is an option in FIFO IP Parameter editor. Sharing the screenshot.
I hope it is clear now.
Thank you
Kshitij Goel
Kshitij_Intel
3 years agoHi,
Yes.
Thank you
Kshitij Goel
