Morten2000's avatar
Morten2000
3 years ago
Older Quartus versions
Hi
My company has used Quartus 16.1 on Windows for many years and all projects are written in 16.1.
I now has to switch computer and install Quartus, but as I understand it 16.1 is no longer available.
I tried to install 21.1, but I can't get Nios/Eclipse to work. I keep getting errors about 'uname is not recognized as an internal command'.
I tried to follow different support tickets and installed WLS, Ubuntu etc. but nothing seems to work.
Are there anywhere a step-by-step guide for installing Quartus/Eclipse on a windows machine?
At what version did Quartus start using the uname command? I might then be able to use version 18 or 19 instead.
  • Morten2000's avatar
    Morten2000
    I have tried to install Quartus and Eclipse on Ubuntu.
    Quartus is running fine, but Eclipse crashes every time I try to open it. I have tried to open it through Quartus, from command promt and from NIOS command prompt, but all of them fails.
    I will try some more, but most likely I just need to use Quartus 18.1.
  • SyafieqS's avatar
    SyafieqS
    Hi Morten,
    Let me know any update on 18.1 Ubuntu status. Did you manage to pass the flow in NIOS BSP?
      Morten2000
      I just use Quartus 18.1 on a Windows PC. That is easy to get working.
      I hope Quartus makes it easier to get it running with WSL before they retire v18.1.
