Morten2000
3 years agoOlder Quartus versions
Hi
My company has used Quartus 16.1 on Windows for many years and all projects are written in 16.1.
I now has to switch computer and install Quartus, but as I understand it 16.1 is no longer avai...
SyafieqS
3 years agoHello Morten,
You may specify the "nios2-bsp-create-settings.exe" in Nios II Command Shell that should solve the issue as below forum
- Morten20003 years ago
I have followed that instructions several times without any luck.
I have my project and I can generate the BSP both from inside Eclipse and from the NIOS II command line.
When I try to build my application I get:
Any ideas?
Is it easier to get it working on a Ubuntu machine or is that just as complicated?
