11 years agoobject "std_logic" is used but not declared
I write this code for 8 bit adder :
Library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_signed.all; --Use work.fulladd_package.all; --------------------------------------------------------------------------- Entity fullAdder is port( Cin : in std_logic; x : in std_logic; y : in std_logic; s : out std_logic; Cout : out std_logic ); end fullAdder; Architecture fullAdder_logic of fullAdder is begin s <= x xor y xor Cin; Cout <= (x and y) or (x and Cin) or (y and Cin); end Architecture; --------------------------------------------------------------------------- Entity eightBitAdder is port( Cin : in std_logic; x : in std_logic_vector(7 downto 0); y : in std_logic_vector(7 downto 0); s : out std_logic_vector(7 downto 0); Cout: out std_logic ); end eightBitAdder; Architecture eightBitAdder_logic of eightBitAdder is component fullAdder port( Cin,x,y : in std_logic; s,Cout : out std_logic ); end component; signal carry : std_logic_vector(8 downto 0); begin carry(0) <= Cin; gen_add: for i in 0 to 7 generate lebel_fulladd: fullAdder port map (carry(i), x(i), y(i), s(i), carry(i + 1)); end generate gen_add; Cout <= carry(8); end Architecture; but it return this error: Error (10482): VHDL error at PartI.vhd(29): object "std_logic" is used but not declared1 Reply
At the top of each entity you need a new set of library/use clauses. They do not carry throughout the file, only the design unit (entity/package) directly below
