11 years agoNumber of processors used during compilation
Hello, can someone explain this Compilation Message: Info (11104): Parallel Compilation has detected 12 hyper-threaded processors. However, the extra hyper-threaded processors will not be used ...
11 years agoHyperthreading actually relies on one thread being 'stalled' (eg waiting for memory or a pipeline flush).
Stalls waiting for the floating point unit may be ok, but it would only apply to trig functions using the x87 not to add/sub/mult/divide. The real problem is that is you have 2 active threads you want them to run on different real processors, not share a single cpu.
