13 years agoThe system id/timestamp seems a bit inconsistent. Even if the same .sopcinfo is used when creating the .SOF file and also for creating the .BSP in Eclipse, the mismatch sometimes appear. Not sure if this is caused by some fault in the HW that I'm working on, but it's clearly confusing Eclipse.
Anyhow, I once again followed the initial procedure, (creating a new Quartus II project, added the <filename>.qsys file, renamed it..etc), and this time it worked(no system id/timestamp mismatch and the memory test is running for successfully for both the Flash and the SRAM devices). I Might have overlooked something, thank you for taking the time to reply. Saber890
