9 years agonot random at each execution
Hi all, I have a problem with generating a random from the uniform function, it is always the same with each execution of the process. I have attached a piece of code to the testbenc...
9 years ago --- Quote Start --- Okay. I'll try a pseudo RNG that i have . It is clear I will be able to change his seed. After I will try to see how to make it change with each simulation launch. --- Quote End --- The best way to do it is to have a generic that assigns the seed, then you can assign this when you launch the simulation.
