9 years agonot random at each execution
Hi all, I have a problem with generating a random from the uniform function, it is always the same with each execution of the process. I have attached a piece of code to the testbenc...
9 years ago --- Quote Start --- It is perfectly psuedorandom - you provide the seed values to determine the sequence. It is important that you can recreate the sequence in verfication. If you run a test with different seeds, only one sequence my produce a fault. Try changing the seeds, and you'll see the sequence is different. --- Quote End --- Thank you for your reactions, that's what I thought. But the seeds are provided by the uniform fucntion, I don't see how to make them change at each exectuion ?
