9 years agonot random at each execution
Hi all, I have a problem with generating a random from the uniform function, it is always the same with each execution of the process. I have attached a piece of code to the testbenc...
9 years agoYour code (once I removed all the illegal signal assignments) works fine:
# ** Note: random is :999
# Time: 40 ns Iteration: 0 Instance: /tester
# ** Note: random is :974
# Time: 50 ns Iteration: 0 Instance: /tester
# ** Note: random is :647
# Time: 60 ns Iteration: 0 Instance: /tester
# ** Note: random is :333
# Time: 70 ns Iteration: 0 Instance: /tester
# ** Note: random is :36
# Time: 80 ns Iteration: 0 Instance: /tester
# ** Note: random is :161
# Time: 90 ns Iteration: 0 Instance: /tester
# ** Note: random is :664
# Time: 100 ns Iteration: 0 Instance: /tester
# ** Note: random is :84
# Time: 110 ns Iteration: 0 Instance: /tester
# ** Note: random is :204
# Time: 120 ns Iteration: 0 Instance: /tester
# ** Note: random is :167
# Time: 130 ns Iteration: 0 Instance: /tester
# ** Note: random is :654
# Time: 140 ns Iteration: 0 Instance: /tester
# ** Note: random is :128
# Time: 150 ns Iteration: 0 Instance: /tester
# ** Note: random is :910
# Time: 160 ns Iteration: 0 Instance: /tester
# ** Note: random is :111
# Time: 170 ns Iteration: 0 Instance: /tester
# ** Note: random is :299
# Time: 180 ns Iteration: 0 Instance: /tester
# ** Note: random is :265
# Time: 190 ns Iteration: 0 Instance: /tester
# ** Note: random is :699
# Time: 200 ns Iteration: 0 Instance: /tester
