15 years agonot fit issue need your help
Error: Selected device has 26 RAM location(s) of type M4K. However, the current design needs more than 26 to successfully fit
Info: List of RAM cells constrained to M4K locations Info: Node " Above is the error i met. I use EP2C5Q208C8 device. And i implemented 32 FIFOs in it, and met this kind of error. The FIFO is 256X1, that is the width is 1bit and depth is 256. So I think that just 2 M4K blocks are enough, but it seems it is not the fact. Can anyone give me your advices? Thanks a lot! Attached is my project, you can download and run it.
