Not able to run the Modelsim simulation in linux
Could you kindly specify the exact version of Linux you are using?
To ensure compatibility, please refer to the OS support information for Modelsim Intel FPGA Edition provided in the following link.
The compatibility is the same as Questa* Intel FPGA Edition.
Here are troubleshooting steps that you may check:
- Try disabling any antivirus or firewall software temporarily, as they may be interfering with the software.
- Run with Administrator privileges.
- Try restarting software and your computer. This can help clear any temporary issues that may be causing the error.
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
