11 years agoNot able to complie NCO entity
Hi there,
I have used NCO in my project. When i compile i get an error as Error (12006): Node instance "inst18" instantiates undefined entity "NCO13" Can anyone help me to resolve this error? Thank you in advance11 Replies
hi,
is it possible to see the part of your hdl code containing the instantiation? thx - Altera_Forum
I think i am missing a library.
There are inconsistencies in the info you've posted with references to 'NCO13' in the error but references to 'NCOex' and 'NCO2' in the block diagram and VHDL respectively. Please make sure you are consistent.
However, fundamentally Quartus doesn't know where to find the design entity - what 'NCO' is. How did you create NCO - via the IP Catalogue (or MegaWizard)? Are the source files for the IP included in your project? As indicated when you generate the IP 'you must manually add the .qip and .sip files after generating the ip core.' Or you can add the IP's .qsys file. So, check under 'Project' -> 'Add/Remove Files in Project...' that there are some files included for your IP. If not, add them. Cheers, Alex - Altera_Forum
i d on't figure why you called it "NCO13". It must be called "NCO2" as you named it. Pretty sure that's why you get an error.
Hi alex,
I am sorry about the confusion. I tried multiple projects. I have created using Mega wizard option. I remember when created the NCO symbol, in my generation report it was not finished. I had to cancel the process. Manually add the symbol. Do you think this might be the case for not compiling? Thanks, Ash - Altera_Forum
hi,
if i use your vhdl file i would write this in the top level entity: nco_inst : nco13 port map( clk => clk_in, reset_n => reset_n ... ); and one more thing i noticed in the first vhdl file you sent : look at reset_n and clk_en, they got the same signal "clk_en". I doubt that reset_n has the same polarity than clk_en. - Altera_Forum
Is 'nco13.qip' included in your project? Check under 'Project' -> 'Add/Remove Files in Project...'
Cheers, Alex
