17 years ago
Node missing source error
I'm having some problems with a schematic design. I'm trying to merge 8 4-bit buses into a 32-bit bus. I've named the buses "nextC[3..0]" etc. and I am feeding them into a bus called "nextC[31..0]".
The error I'm getting is:
"Error: Node "nextC[0]" is missing source"
"Error: Node "nextC[1]" is missing source"
"Error: Node "nextC[2]" is missing source"
"Error: Node "nextC[31]" is missing source"
I don't understand why I'm getting the error. The 4-bit buses are connected to other 4-bit buses.
    I am also getting this error when I connect an 8-bit bus to the 8-bit output of a lpm_ff. The bus is named q[7..0] and is connected using a bus line to q[7..0] of the DFF. This seems coorect yet I get a compiler error "Error: Node "q0" is missing source" for each signal.
    Any help is appreciated.
    --- Quote Start ---
    --- Quote End ---
    can you post your schematic ?
    Did you connect every node of nextC[3..0] with a wire (with the corresponding net name) coming from the original bus?
    I posted the section of the schematic with the errors. Ignore the logic since it's randomly connected after the cutout. The compiler says:
    Warning: No superset bus at connection <---the dest bus
    Warning: Pin "DIN6" not connected
    Warning: Pin "DIN5" not connected
    Warning: Pin "DIN4" not connected
    Warning: Pin "DIN3" not connected
    Warning: Pin "DIN2" not connected
    Warning: Pin "DIN1" not connected
    Warning: Pin "DIN0" not connected
    Warning: Pin "DIN7" not connected
    Error: Node "dest7" is missing source
    Error: Node "dest6" is missing source
    Error: Node "dest5" is missing source
    Error: Node "dest4" is missing source
    Error: Node "dest0" is missing source
    Error: Node "dest1" is missing source
    Error: Node "dest2" is missing source
    Error: Node "dest3" is missing source
    Error: Node "din[7]" is missing source
    Error: Node "din[6]" is missing source
    Error: Node "din[5]" is missing source
    Error: Node "din[4]" is missing source
    Error: Node "din[3]" is missing source
    Error: Node "din[2]" is missing source
    Error: Node "din[1]" is missing source
    Error: Node "din[0]" is missing source
    I've check the drafting and all lines seem properly connected. I tried redrawing, renaming and reconfiguring and it didn't get rid of the errors. Replacing the individual pins for din[7..0] with a singe bus pin did fix the "node din(x) missing source" error.
    Yeah, instead of writing din7, din6 and so on you have to write din[7], din[6], etc. on each wire.
    The same for dest: dest[7], dest[6], etc.
    It will work!
    Cheers
    OD
    That worked!!! Thank you OrchestraDirector. The examples in the Atera help screens don't use brackets and that was my stumbling point.
