node find post-compilation
I found in the node find GUI
the post-compilation filter misleading.
I first told it was after VHDL or Verilog compilation step,
but it seems to be after the full compilation run,
as the GUI indicates me that the post-compilation search shall be run after the fitter.
It would be better to change the "post-compilation" into "post-fit",
similar to the signal tap search.
Can you change this in future Quartus version?
Kind Regards,
Alex.
- sstrell
Post compilation is just what it says: after a full compilation. Other steps may run after the Fitter (like hyper-retimer) so post-compilation is looking at a final netlist after all compilation steps have completed.
- AEsqu
Contributor
Post compilation does not says full compilation.
I would then name it Post full compilation
- sstrell
Agree to disagree.
- SyafieqS
Thanks for your feedback.
it is a agree to disagree at some point but I can forward this to the developer for them to decide.
- AEsqu
Contributor
Please forward the proposal to the dev, Thank You SyafieqS!
- SyafieqS
Appreciate your feedback. I am forwarding this to the developer to. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
- AEsqu
Contributor
the link is incorrect, it points to an empty page,
Shall the link be https://supporttickets.intel.com instead, like the one visible?
See attached picture.
- SyafieqS
You are correct, I might be using wrong link.
Thanks for the update.
