13 years agoHi
Here's the controller code:-- SRAM
nCE<='0';
nLB<='0';
nUB<='0';
mem <= '1' WHEN wrusedw_fv<100 ELSE
'0';
rw <= '0';
---------------------------------------------------------- SRAM CONTROLER STATE MACHINE
next_state <= r1 WHEN current_state=idle and mem='1' and rw='0' ELSE
w1 WHEN current_state=idle and mem='1' and rw='1' ELSE
r2 WHEN current_state=r1 ELSE
w2 WHEN current_state=w1 ELSE
idle;
PROCESS (clk150MHz) IS
BEGIN
IF rr='1' THEN
current_state<=idle;
ELSE
If clk150MHz'event and clk150MHz='1' Then
current_state<=next_state;
End If;
END IF;
END PROCESS;
----------------------------------------------------------VGA Fifo write request
WITH current_state select
wrreq_fv <= '1' WHEN r2,
'0' WHEN OTHERS;
----------------------------------------------------------Write Enable and Output ENABLE
WITH next_state select
nWE_buf <= '1' WHEN r1 | r2 | idle,
'0' WHEN OTHERS;
WITH next_state select --
nOE_buf <= '1' WHEN w1 | w2,
'0' WHEN OTHERS;
BEGIN
IF rr='1' THEN
nWE<='1';
nOE<='1';
ELSE
nWE<=nWE_buf;
nOE<=nOE_buf;
End If;
END IF;
END PROCESS;
nWEout<=nWE;
nOEout<=nOE;
--Adreses OUT---------------------------------------
ADDR_val <= ADDR_read WHEN r1,
ADDR_write WHEN w1,
ADDR_reg WHEN OTHERS;
BEGIN
IF rr='1' THEN
ADDR_reg<=0;
ELSE
ADDR_reg<=ADDR_val;
End If;
END IF;
END PROCESS;
ADDR<=conv_std_logic_vector(ADDR_reg, 18);
--Adreses rw---------------------------------------
ADDR_read_temp<=0 WHEN current_state=r1 and ADDR_read=ram_max ELSE
ADDR_read+1 WHEN current_state=r1 ELSE
ADDR_read;
ADDR_write_temp<=0 WHEN current_state=w1 and ADDR_write=ram_max ELSE
ADDR_write+1 WHEN current_state=w1 ELSE
ADDR_write;
BEGIN
IF rr='1' THEN
ADDR_read<=0;
ADDR_write<=0;
ELSE
IF clk150MHz'event and clk150MHz='1' THEN
ADDR_read<=ADDR_read_temp;
ADDR_write<=ADDR_write_temp;
End If;
END IF;
END PROCESS;
ADDR_read_out<=ADDR_read;
ADDR_write_out<=ADDR_write;
--Data----------------------------------------------------
DataIO <= "ZZZZZZZZZZZZZZZZ" WHEN r1 | r2,
Data_to_ram WHEN w1 | w2,
DataIO WHEN OTHERS;
Data_from_ram<= DataIO WHEN r2,
Data_from_ram WHEN OTHERS;
---------------------------------------------------------- I will give some comments on the code if needed in the evening (GMT+2 :))! Thanks!
