18 years agoThanks FvM. You are probably correct in that a 4ns programmable delay is not possible to achieve (possibly because i'm not using output registers). The LCELL approach works fine so i'll leave it at that - the clock frequency is only 120 MHz so i have lots of wiggle room before the timings break down so this should work fine.
