18 years agoProbably get rid of the clock name in the From column and just leave the port name in the To column. This is how I usually see it. I thought the clock name would work, but it's definitely not necessary. (If you have multiple registers driving out, then put the name of the register in the From column. I've seen this when the data and OE registers have different Tco requirements.)
