18 years agoIf you're doing device-centric constraints(like Tsu and Th on the input ports), then on the output side you want to use Tco and Min Tco constraints. Most user's just apply Tco and Min Tco directly to the port(in the To column, as all single-point assignments are there), and leave it at that. (And as always look at TimeQuest when you get a chance...)
