15 years agoHi,
I have this problem also and have not found a solution. In my situation, Quartus II 8.0 Web Edition does not work on Microsoft Windows XP Professional Version 2002 Service Pack 3. I've recently acquired a NIOS Embedded Evaluation Kit (NEEK) and installed the Quartus version from the packaged DVD. I am following the "my_first_fpga_tutorial.pdf" included in the kit and when I try to create the pin assignments, the Pin Planner does not produce any input/output pins I've created earlier. Thank You, Jason
