15 years agoFrankAtEsi,
You previously said that you were able to install in two other XP systems. Can you confirm that you do not have the "HP PCL6 print spool drivers" running? And have you try disabling this driver to see if Quartus works? It seems like Qt has some problems with Printer drivers. It will be nice to confirm that this is the issue. Thanks, - David Altera
