15 years ago --- Quote Start --- All machines are running the identical project. XPSystem1 fails to compile anything, and generates no errors or reports. I simply reports: Info: You have a valid up-to-date license Info: You have a valid up-to-date license Info: You have a valid up-to-date license Info: You have a valid up-to-date license Info: You have a valid up-to-date license Info: You have a valid up-to-date license Info: Quartus II Full Compilation was successful. 0 errors, 0 warnings This entire process only takes 20 seconds, where the entire compile takes 10-15 minutes on the other machines. Running the Altera sample project "fir_filter" in the qdesigns directory, the results and timing are identical. Only 2 files are ceated in the sample directory, type .qdf and .done. THere are no reports or summary or compiled files. The db directory is created, but only gets 4 skeleton files type .info,.sci,.qmsg, and .tmw_info. Any help on what to try would be appreciated. --- Quote End --- Hello Frank, I gave up in the end. Like you said maybe it will work on another computer but its not a good result for a free version of software. Also why is this software so large ?? 3 Gigs !! Compared to MaxPlus it is massive !! And what on earth are they using Cygwin for ? Has this software been developed for Unix and ported across to Windows ?? regards david
