15 years ago --- Quote Start --- Ok, this is very unusual. Can you try exiting Quartus and going to the command-line console (Windows CMD), and trying from the comman-line: quartus_map <your project name> (The project name should be the name of the QSF file) Did quartus_map generate a <project name>.map.rpt file? Did it generate a "db" directory? What's in the "db" directory? Can you confirm you have enough disk space and that your directory is writable? -DK --- Quote End --- Yes I did that and it comes back with the following in green text "Info: You have a valid up_to_date license" There is no rpt file either and the db directory was already there. Maybe I should reinstall it ?
