15 years agoOk, this is very unusual.
Can you try exiting Quartus and going to the command-line console (Windows CMD), and trying from the comman-line: quartus_map <your project name> (The project name should be the name of the QSF file) Did quartus_map generate a <project name>.map.rpt file? Did it generate a "db" directory? What's in the "db" directory? Can you confirm you have enough disk space and that your directory is writable? -DK
