no "Report" window in Timing Analyzer
Win10-64b . Not the compilation report window in Quartus, the timing "Report" window in the "Timing Analyzer tool".
I have since figured it out, and I believe the behavior is different than it used to be. What happens now is that if I create timing reports in the Timing Analyzer Tool, their results are "sent back" to the main Quartus "Compilation Report" window, under a new section labeled "Timing Analyzer GUI". The old behavior I was expecting was that in the Timing Analyzer Tool itself, a new panel would be created called "Report" which would hold the results of all the reports that I asked for. Now that I see and understand what's going on, I actually like this behavior better because the report results persist even after I close the Timing Analyzer tool window.
Thanks!
