cdmski
3 years agoNo output depends on input (outputs stuck at VCC or GND) errors
I'm attempting to implement simple power sequencing logic in a MAX10 fpga.
There are four groups of power regulators that are enabled sequentially when the each regulator in the preceding group sup...
- 3 years ago
Weird. Other things I notice: you have 6 states, but you set S_FSM_ERROR as 'x (and only using 5 bits for the state). It should probably have a defined value. Also, even though you are manually doing one-hot encoding here, did you create a state machine encoding assignment in the Assignment Editor?
AqidAyman_Altera
3 years agoI’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
