No output depends on input (outputs stuck at VCC or GND) errors
- 3 years ago
Weird. Other things I notice: you have 6 states, but you set S_FSM_ERROR as 'x (and only using 5 bits for the state). It should probably have a defined value. Also, even though you are manually doing one-hot encoding here, did you create a state machine encoding assignment in the Assignment Editor?
It turns out that my issue was caused by using 'x in my typedef state enum after all.
Something must have changed, or this project's settings are slightly different in some way because I have used this construct successfully before.
typedef enum logic [4:0] {
S_REBOOT = 5'b0_0001,
S_GROUP_1_EN = 5'b0_0010,
S_GROUP_2_EN = 5'b0_0100,
S_GROUP_3_EN = 5'b0_1000,
S_PS_DONE = 5'b1_0000,
S_FSM_ERROR = 'x <-- Removing this fixed my issue.
} state_e;
state_e state;
I then decided to add in another state for error catching (the default case switch sends the FSM to this state) and let the compiler assign enum values automatically:
localparam STATE_NUM = 6;
typedef enum logic [STATE_NUM - 1 : 0] {
S_REBOOT,
S_GROUP_1_EN,
S_GROUP_2_EN,
S_GROUP_3_EN,
S_PS_DONE,
S_FSM_ERROR
} state_e;
state_e state;
