No output depends on input (outputs stuck at VCC or GND) errors
- 3 years ago
Weird. Other things I notice: you have 6 states, but you set S_FSM_ERROR as 'x (and only using 5 bits for the state). It should probably have a defined value. Also, even though you are manually doing one-hot encoding here, did you create a state machine encoding assignment in the Assignment Editor?
Create a "State Machine Processing" assignment in the Assignment Editor and set the encoding style appropriately.
I added the "State Machine Processing" assignment, but am still seeing the issue.
I think a big part of my problem is that the project doesn't think that "Clock_25MHz_Max10" or "RESETn" have outputs that are dependent on them. I've tried using "Clock_25MHz_Max10" directly by bypassing the PLL. I've tried adding "set_instance_assignment -name GLOBAL_SIGNAL GLOBAL_CLOCK -to "Clock_25MHz_Max10" " into my .qsf.
Could the .sdc cause this isue?
At the moment I have an .sdc that has:
set_time_format -unit ns -decimal_places 3
create_clock -period 40 [get_ports Clock_25MHz_Max10]
derive_pll_clocks
derive_clock_uncertainty
