No output depends on input (outputs stuck at VCC or GND) errors
- 3 years ago
Weird. Other things I notice: you have 6 states, but you set S_FSM_ERROR as 'x (and only using 5 bits for the state). It should probably have a defined value. Also, even though you are manually doing one-hot encoding here, did you create a state machine encoding assignment in the Assignment Editor?
This paper (http://www.sunburst-design.com/papers/CummingsSNUG2019SV_FSM1.pdf) also makes use of a don't care state to account for the unused states in the typedef state enumeration. I have used this coding style before without issue.
I'm unfamiliar with creating a state machine encoding assignment, but I do know that a state machine is being inferred by this code as it appears as designed in the "Analysis and Synthesis - State Machine" output.
