16 years agoI don't know vhdl (only verilog). But here is a stab at it.
1. It looks like your display process is the only part dependent on CLK_OUT. 2. Its functionality is to ultiimately set a new value in sVID_DWORD. 3. VID_OUT is assigned to sVID_DWORD. 4. VID_OUT is in your entity port list as an output. Therefore, if you have not assigned VID_OUT to output pins in the higher level module which instantiates this one, the code will be optimized away. Therefore, this would make sense: Warning: Design contains 1 input pin(s) that do not drive logic and so would: Warning (15610): No output dependent on input pin "CLKOUT" I'd check that you have correctly assigned the VID_OUT signal to actual hardware pins on the FPGA.
