No HLS folder in Quartus Prime Pro 18.1
I only see a HLD folder and not a HLS folder in the Intel Quartus Prime Pro version.
Can you please verify?
Nivetha
- AnandRaj_S_Intel
Hi Nivetha,
This is a known issue.
Kindly follow the Knowledge answer in this link:
Anand
- NSuku1
Hi Anand,
Does the patch works on 17.1 pro version as well?
Kindly confirm.
Nivetha
- AnandRaj_S_Intel
Hi Nivetha,
Apologies for late response,
The Intel HLS Compiler is included in the Windows release of Intel Quartus Prime Design Software Version v17.1.
However Patch is created for 18.1 Pro. You must either have previously installed the Quartus Prime 18.1 software or must install the Quartus Prime 18.1 software before installing this patch. Otherwise, the patch will not be installed correctly and the Quartus Prime software will not run properly.
Anand
